Author Topic: Signing Add-In with a strong name, sometimes it's needed?  (Read 8728 times)
Helmut Ortmann
« on: May 26, 2018, 05:20:25 pm »
I come across that registering of an Add-In usually works without bothering about .net signing in C#.
Last time I couldn't register an unsigned DLL with EA to use as GUI/COM object in the Add-In window. After signing everything runs smooth.
In debug mode of VS 2017 everything runs smooth, regardless of signing or not. So, I'm a bit puzzled.
The thing is: In the past, everything works fine with a lot of Add-Ins, regardless of signing or not. I've searched a lot and I've found a lot about the signing of dlls, no silver bullet.
Any idea?
Helmut
EXploringEA
Re: Signing Add-In with a strong name, sometimes it's needed?
« Reply #1 on: May 31, 2018, 01:07:58 am »
Hi Helmut
Reading your post I have a vague recollection of a similar issue years ago where I ended up having to sign a DLL, but then miraculously the problem just disappeared after a few days so I didn't explore further.
Also, it wasn't clear from your post whether the problem happens on the same machine and for same users or not.
Thinking about what it could be:
If this isn't for a single user/machine my guess would be that it is related to some windows policy.  On taking a quick look Windows local security policy supports rule based actions for DLL's with AppLocker.  In this case it may be worth a look there to see if any rules configured for users / admin.  But a word of warning this is not an area where I have personally done a lot, I'm just aware of cases working with different systems where administrators have set machine/user policies that caused us issues.
Be interested to know the outcome.
BR
Adrian
EXploringEA - information, utilities and addins
Helmut Ortmann
« Reply #2 on: May 31, 2018, 07:04:54 am »
Hi Adrian,
thanks for your elaborate answer.
It is the same user, the same machine and the dll is installed as per user.
I just tried it once more with the same user, and the same machine. Without signing it doesn't install the Add-In GUI and with signing it installs the Add-In EA GUI.
Because I can live with signing I'm not that keen on testing and trying.  There is always the possibility to sign an used external dll. All other Add-Ins run smoothly.
If I come along with an explanation I'll inform you.
Best regards,
Helmut
Helmut Ortmann
« Reply #3 on: June 15, 2018, 09:29:02 pm »
Hi Adrian,
it looks as if I have solved the issue. The NeutralResourcesLanguage should be correct and the same for all dlls. Maybe it's best to avoid specifying a neutral language altogether. It looks complicated but now it works.
Witout strong name for a DLL (assembly properties)
[assembly: NeutralResourcesLanguage("en")]  // I had used english-europe (en-150) for one dll
or just:
[assembly: NeutralResourcesLanguage("")]
If I've correctly read the documentation strong names support dll with version and culture.
Best regards,
Helmut
EXploringEA
« Reply #4 on: June 16, 2018, 07:40:50 pm »
Hi Helmut
Thanks for the information - I'd better make a note of this for future reference.  It is something I would never have thought about - what gave you the clue or was it just luck you found the solution?
BR
Adrian
Helmut Ortmann
« Reply #5 on: June 25, 2018, 05:57:10 am »
Hi Adrian,
it was just luck!
I wanted to check the release of the dll and used my "About" functionality which lists all dll releases. This function tries to load the dll in question and reported a meaningful error message.
After fixing the error I haven't investigated it deeper. Maybe just loading a dll is a mean for this kind of error.
Best regards,
Helmut
EXploringEA
« Reply #6 on: June 25, 2018, 05:45:45 pm »
Helmut,
Seems like a valid experiment rather than pure luck, and fortunate that you got a meaningful message!
All makes sense as loading the AddIn DLL is exactly what EA does.
Good to have a logical reason (and test).
BR
Adrian
