Author Topic: System Resource Exceeded on Large Deletes  (Read 12583 times)
Rich Anderson
    • LinkedIn
« on: May 28, 2018, 12:37:07 pm »
Hi There, I'm having problems deleting packages with lots of elements and attributes, frequently getting the dreaded "System Resource Exceeded" message.  The only workaround I have found was to restart EA and delete the package in smaller parts. (I could write a script, but I'd rather not).  I've scoured the messages to see if anyone has had this problem and did not find anything.  I've also filed a but with Sparx because I've seen this recommended also, but I thought I would ask.   I do this a lot because I'm writing code that generates lots of elements, so in my testing I frequently need to delete packages that are quite large.   I'm using the standard EAP file on my desktop.
Rich Anderson
Urgnt Limited
Nizam
  • Prolab Moderator
  • Model Sharing - Simplified
Re: System Resource Exceeded on Large Deletes
« Reply #1 on: May 28, 2018, 12:52:31 pm »
I've seen this mostly when we try some large operation in an EAP file (MS Access).
Whilst i would suggest a Project Integrity Check / Repair EAP to start with (if you are using EAP), I'm not sure if this will fix the issue.
AFAIK there was some registry fix for a similar error (https://support.microsoft.com/en-us/help/198633/you-receive-an-file-sharing-lock-count-exceeded-error-message-when-you), Not sure if there is one for the System Resource Exceeded error (check this https://social.msdn.microsoft.com/Forums/en-US/53597e95-5ca0-44d7-a381-1888f70c301a/ms-access-system-resource-exceeded-error-message?forum=accessdev)
If you are connecting to the server,  check the below link too
https://serverfault.com/questions/881262/system-resource-exceeded-what-resource-could-that-be
VKN
« Reply #2 on: May 28, 2018, 01:11:27 pm »
That error is from the DB engine, not EA itself.
There is no workaround for it, you'll need to delete in smaller chunks.
« Reply #3 on: May 28, 2018, 01:12:53 pm »
Hi Rich,
if it's only on .EAP files, you might try changing the Access Locks count in the registry.
Nizam
  • Prolab Moderator
« Reply #4 on: May 28, 2018, 02:32:54 pm »
Hi Rich,
Reference for this.
Rich Anderson
    • LinkedIn
« Reply #5 on: May 29, 2018, 08:58:18 am »
Hi Guys, I couldn't actually find the registry entries mentioned in these articles. Even searching the registry would not find them.  I think I'll just write a script that recursively goes through all the packages, sub-package and elements and deletes them one at a time.  It seems to me that this should be an option in EA itself. It would be something like "Execute deletes as separate transactions (helpful for large deletes)" with a checkbox.
Rich Anderson
Urgnt Limited
Nizam
  • Prolab Moderator
« Reply #6 on: May 29, 2018, 09:39:47 am »
Agreed, such an option will be helpful.
Refer to http://www.sparxsystems.com/forums/smf/index.php/topic,17906.msg242877.html#msg242877
for the registry key related discussion
« Reply #7 on: May 29, 2018, 09:49:21 am »
Yes, the option would be useful.
We're also finding some queries (internal to EA) which generate overly large sets which tax the system on our production repository.  Fortunately, we've learnt that when they fail, nothing bad (appears to) happens.  So we just ignore them, but it would be better if they didn't occur.
Nizam
  • Prolab Moderator
« Reply #8 on: May 29, 2018, 10:24:39 am »
Another instance where we've seen this is when trying to import a fairly large DB Schema, 900+ tables precisely.
« Reply #9 on: May 29, 2018, 12:40:20 pm »
Just got one a few minutes ago, doing just that!
It seems like we got the Oracle Reverse Engineering going (see another topic) only to get this...  The Reverse Engineer is still running (at time of writing) so I can't tell how big the source DB was.
BTW Nizam, was there any impact of the error?
« Last Edit: May 29, 2018, 12:41:58 pm by Paolo F Cantoni »
Nizam
  • Prolab Moderator
« Reply #10 on: May 29, 2018, 01:59:30 pm »
We couldn't succeed with import even after changing the Registry setting (EA just froze), so we ended up importing in parts.
(obviously compromising the inter-relationships between entities).
« Reply #11 on: May 29, 2018, 02:56:07 pm »
We upgraded the user to b1421 and although we got the error, the RE seemed to complete.  2355 Tables (with, apparently, NO FK Constraints defined).
Nizam
  • Prolab Moderator
« Reply #12 on: May 29, 2018, 03:17:08 pm »
Thats good to know, will suggest this to the client and suggest to try again (if they are still onto it :))
