Author Topic: Oracle Reverse Engineer  (Read 30031 times)
« on: May 28, 2018, 02:55:51 pm »
One of our users is trying to reverse engineer an Oracle DB.
We're usually a SQL Server shop, so I haven't done one of these for ages.  Using b1351, he seems to be doing all the right things on the Import from ODBC dialog.  Are there any "gotchas", "secret sauces" that we should be using?
The result is that after asking it to reverse engineer everything, for the tables, we get the table objects, no features or relationships - just empty boxes...
TIA,
Sunshine
  • Its the results that count
Re: Oracle Reverse Engineer
« Reply #1 on: May 28, 2018, 09:44:19 pm »
Done a couple of oracle databases and never been able to get the relationships either. Fortunately the primary keys and foreign keys where named consistently that i wrote a script to create the relationships. Not ideal but i ended up with the desired result.
« Last Edit: May 30, 2018, 06:34:41 am by Sunshine »
Happy to help
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« Reply #2 on: May 29, 2018, 05:00:57 am »
Are you using legacy reverse engineering? Have you tried Database Builder?
hd
« Reply #3 on: May 29, 2018, 08:20:48 am »
Make sure the ODBC driver is the Oracle driver and not the "Microsoft ODBC for Oracle" driver.
« Reply #4 on: May 29, 2018, 09:45:08 am »
Yes (I think so), I'll give it a go!
[EDIT: I tried it, but it seems to me that the import DB Schema is the SAME dialog as the non-Database Builder route.  I tried an SQL Server DB (as my user isn't in yet) and both routes worked fine.]
« Last Edit: May 29, 2018, 11:17:11 am by Paolo F Cantoni »
« Reply #5 on: May 29, 2018, 09:46:13 am »
Will do, when I get in to work.
I should get both the columns AND the FK relationship, yes?
Glassboy
« Reply #6 on: May 29, 2018, 01:17:16 pm »
It's been a few years since I reverse engineered an Oracle DB but I remember getting everything.
« Reply #7 on: May 29, 2018, 04:39:25 pm »
A combination of V14 and the DB Builder (we were using the Oracle ODBC drive - 11.0.2.1) did it.
We imported 2355 tables, 159 views etc...   However, we got a Resources Exceeded message and thought it might have damaged the FK Constraint import.  But it seems that this product hasn't got any FK Constraints!
« Reply #8 on: May 29, 2018, 04:58:27 pm »
Who in his right mind would design a database without FK constraints!  :o
Ohh, um, ... nevermind...  :-X
Richard Freggi
« Reply #9 on: May 29, 2018, 10:10:38 pm »
I'm not an Oracle expert but any RDBMS should spit out the schema DDL code as a text file on request.  Then just run the DDL in EA to recreate the schema as a physical data model?
« Reply #10 on: May 30, 2018, 12:00:01 am »
Why do it the simple way if you can go through a variety of ODBC and native drivers instead?
Sunshine
« Reply #11 on: May 30, 2018, 06:48:45 am »
Interesting I didn't know you could run DDL in EA to recreate the schema. I've search the help and can't find anything on that particular feature. Care to share a reference on how to access it?
Happy to help
Sunshine
« Reply #12 on: May 30, 2018, 06:50:48 am »
Probably because the help tells you to use ODBC drivers. Haven't found out how to run DDL in EA yet though. Still searching in the online help for that feature.
https://www.sparxsystems.com/downloads/resources/booklets/uml_code_engineering.pdf
Happy to help
« Reply #13 on: May 30, 2018, 08:56:23 am »
EA can't reverse engineer a DB schema from a sql file.
« Reply #14 on: May 30, 2018, 05:27:29 pm »
Yes, I know that EA can't RE a DDL. Unfortunately there's no emphasis for irony/sarcasm in texts.
