Author Topic: Test Oracle connectivity using sqlplus without password  (Read 3270 times)
soujanyabargavi
« on: May 29, 2018, 05:03:57 pm »
I am in a unique situation where I need to test my server connectivity to Oracle databases however I do not have access to any account or password.
Reason why the connectivity needs to be tested is because many times there are multiple layers of firewalls between my servers and the database, and also particularly recently while trying to access RAC/Exadata databases we realized that doing a telnet on the "scan" IP range (which were the only range visible to me) was not enough and that there are underlying physical/virtual IPs that are actually used to connect which were blocked. If I can test connectivity I can at least confirm the database is accessible.
I thought about connecting using sqlplus test@DB, where "test" account doesn't actually exist. If I get a reply saying that incorrect username/password logon denied, then at least I know the database connectivity is working because at least it reached the database to perform authentication. But I have audit concerns (whether DBAs will think someone is trying to hack the system) and also whether there's an actual way or command to do this test.
Re: Test Oracle connectivity using sqlplus without password
« Reply #1 on: May 29, 2018, 06:42:20 pm »
Is this in any way related to EA?
Or is it spam? I can't tell  :-\
