Author Topic: MDG : Error with Extension to MetaClass ???  (Read 7330 times)
Mesple
« on: May 31, 2018, 12:45:57 am »
Hi all,
I'm using the last version V14.
I'd like to update my MDG Techno, by adding a new stereotype "A" from an existing metaclass "B".
And I've the following error msg when I create the "Extension" link between "A" and "B" : "The requested connection is not UML compliant"
Thanks for your help!
Olivier
Nizam
  • Prolab Moderator
  • Model Sharing - Simplified
Re: MDG : Error with Extension to MetaClass ???
« Reply #1 on: May 31, 2018, 09:12:23 am »
You have to use 'Generalize' if you are extending from a stereotype, it is a recommended practice to also have the actual meta class (that A extends) included in teh definition and have an extend connector from B to the Metaclass
So B must be a Subtype of A and extend the Metaclass.
Mesple
« Reply #2 on: May 31, 2018, 05:32:38 pm »
Thanks for your response  :) but unfortunatly, it doesn't work.
Same msg : "The requested connection is not UML compliant" whatever the type of the link between the "metaclass" and the "stereotype" objects.
I suppose that I have probems with EA parameters or MDG Technology?
If I select a metaclass object in my profile diagram, the quick linker doesn't propose any stereotype to extend?
Any idea?
Olivier
« Reply #3 on: May 31, 2018, 06:03:35 pm »
I'm not sure if you are doing something wrong or not, but you can bypass the error message by turning off the strict connector syntax option in the settings.
Mesple
« Reply #4 on: May 31, 2018, 06:28:50 pm »
Thanks Geert :-)
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« Reply #5 on: June 03, 2018, 09:39:20 am »
I'm experimenting the same issue. Extending metaclasses is not working as always. Build 1421
Nizam
  • Prolab Moderator
« Reply #6 on: June 03, 2018, 09:32:57 pm »
even after disabling strict syntax?
Guillaume
    • www.umlchannel.com
« Reply #7 on: September 12, 2018, 05:47:24 pm »
As a side note, I always followed this practice of extend the MetaClass e.g. Class and create a Generalization to the existing Stereotype (e.g. Archimate, SysML...).
I noticed that it works when I don't extend the Metaclass but only use a Generalization. Hence I wonder if there's any use in including the Metaclass.
Guillaume
« Reply #8 on: September 12, 2018, 06:38:00 pm »
I did run into problems when not including the extension of the metaclass in my profile.
Seems like a bug to me, but for the moment I'm still including the metaclass relation to the profile.
Guillaume
« Reply #9 on: September 12, 2018, 09:08:32 pm »
Thanks for the info Geert.
Guillaume
