Author Topic: EA14 : operation parameters and rename an image asset  (Read 8196 times)
Guillaume
    • www.umlchannel.com
« on: May 31, 2018, 04:49:05 pm »
Using EA14 Build 1420, I'm working with class operations. The Features&Properties view works fine to create new operations, but the Operations Properties doesn't let me enter anything.
I double click on the Parameters cell of an operation in Features&Properties -> Operation Properties opens up. Then all the fields are greyed out/disabled.
I also found an issue in using Image Assets: pressing F2 doesn't let me rename the element.
Guillaume
VKN
Re: EA14 : operation parameters and rename an image asset
« Reply #1 on: June 01, 2018, 01:42:27 pm »
A parameter need to be in context/selected to be able to edit those fields.
Make sure that the Features&Properties->Operation Properties window is vertically long enough then add the parameters in the bottom part of that window.
Guillaume
« Reply #2 on: June 01, 2018, 04:41:49 pm »
The view height was indeed too small to see the list of parameters. It's a tricky UI design issue as moving the list at the top mayh make it difficult to update the parameters details..
Guillaume
nemethmik
« Reply #3 on: October 01, 2018, 06:37:23 pm »
Thank you VKN.
I had the same issue. Couldn't we just get back the classic UI? Honestly, this new UI is a nightmare.
Thank you and all the best,
Miklos
« Reply #4 on: October 01, 2018, 07:10:50 pm »
You can. In v14.1 there is an option to bring back the old features dialog.
Visual Style | Prefer property dialogs
heba
« Reply #5 on: October 10, 2018, 11:54:49 pm »
Thank you!  That saved my day, I guess ;-)
