Author Topic: EAP-to-DBMS model transfer  (Read 10715 times)
crequena
« on: May 31, 2018, 08:32:26 pm »
I see there is no automation to perform an EAP-to-DBMS operation.
http://www.sparxsystems.com/enterprise_architect_user_guide/14.0/automation/project_2.html
Does anyone know any alternative to do this without using EA's GUI?
Thanks.
Re: EAP-to-DBMS model transfer
« Reply #1 on: May 31, 2018, 09:20:18 pm »
For what purpose do you want to automate that? And between which RDBMS?
« Reply #2 on: May 31, 2018, 11:05:48 pm »
Have you tried it?
I could image that it could work if you simply entered the .eap file as source, and the DB connectionstring as target.
crequena
« Reply #3 on: June 01, 2018, 12:36:03 am »
It's a SQLServer db.
Invoking the ProjectTransfer method from eap to dbms file just returns "false" and does nothing with the database.
Also, nothing gets logged.
It's not working neither from Java nor PowerShell:
$ea = New-Object -ComObject "EA.Repository" -Strict
$project = $ea.GetProjectInterface()
$project.ProjectTransfer("....eap", "DBType=1;Connect=Provider=SQLOLEDB.1;Persist Security Info=True;User ID=...;Password=...;Initial Catalog=...;Data Source=...", "D:\....DBMS.log")
$ea.Exit()
« Reply #4 on: June 01, 2018, 01:43:47 am »
Too bad, it was worth a shot.
Apart from copying the data table by table yourself, I don't really see a solution.
« Reply #5 on: June 01, 2018, 05:56:59 am »
I never tried that. The documentation seems to read as "works for EAP to EAP only" since they talk of file paths. Hmm. You should probably contact Sparx support. Likely they will respond "this is intentional" rather than "other DBs are missing and we'll fix that". But you never know.
Sunshine
  • Its the results that count
« Reply #6 on: June 01, 2018, 08:56:09 am »
As eap files are MS Access you could have a look to see if MS Access has anything built in to do the transfer and see if you could automate it.
Alternatively if you have some coin you could use an ETL tool like informatica or similar to do the transfer.
Happy to help
« Reply #7 on: June 01, 2018, 03:05:05 pm »
It works fine from DBMS to .eap, which is probably its main use: create a usable backup file of your DBMS model.
Nizam
  • Prolab Moderator
  • Model Sharing - Simplified
« Reply #8 on: June 02, 2018, 12:15:18 am »
True, but it will be really good to have DBMS to DBMS, we are doing a number of workarounds for backing up large models (as migrating to EAP files mostly fails)
Sunshine
« Reply #9 on: June 02, 2018, 11:06:55 am »
Yeah I do that too backing up a SQL repository to eapx file. We have SQL database back up daily too but don't have confidence in our support vendor so the eapx files are a insurance policy. Upto around a 1GB now.
Happy to help
« Reply #10 on: June 04, 2018, 09:17:42 am »
The API call for ProjectTransfer intentionally only targets eap files. It's their as a backup mechanism, and we don't want it to be possible to destroy a model using it.
crequena
« Reply #11 on: June 14, 2018, 11:56:17 pm »
Thank all for your replies.
