Author Topic: EA build 1421: problem with connector on the Business Process Diagram  (Read 8051 times)
aleksandra_k
During work with one of my developed business process diagram I encountered a problem with connectors between two UML elements. If you connect two elements ones, you can't change this connection - you can't drag the existing connector to another element.
In the earlier version (build 1420) i haven't observed such problem, so it looks like a serious bug to me.
I wonder, if anyone has observed such odd behaviour?
Ola
I am certainly able to create a connector between two elements on a diagram and drag the connector to another element. I suspect we are using different kinds of diagram, element and/or connector. Could you be more specific please?
aleksandra_k
I suppose that my problem is quite trivial, but I can't find the solution :(
I try to drag an existing connector on a BPMN 2.0 diagram between two activities and it doesn't work. However I can create new control flow connectors.
I'm sure that it is not a problem with EA version, because I restored to EA 13.5 and the connector still haven't work properly (before the actualisation to EA 14 I didn't observe such problem). What is more, on the other program instance, on another computer (EA build 1420) I work with the same project and my problem haven't  occur...
Have you got any idea?
Ola
RoyC
  • Read The Help!
Maybe on the problem system you have strict UML Syntax enabled, whilst it isn't enabled on the other installation?
Best Regards, Roy
aleksandra_k
Yes, I have the Strict Connector Syntax option selected in my link's preferences.
Today morning I compared preferences on my EA (build 1421) and on the other one (build 1420) and we have the same settings - in both case the  Strict Connector Syntax option is checked.
So I am a bit confused, but I am happy that it eventually works!
Thanks a lot.
Ola
