Author Topic: Publish as HTML don't work in EA 14  (Read 3652 times)
nkoppaka
« on: June 07, 2018, 02:50:14 am »
I am trying to publish a package as HTML report. I was able to do this in v 13 before i upgarded to v14. Since when i upgraded, i am not able to run the HTML Publish option. It says an error occured and nothing else.
DO anyone got this issue. Also i want to see what error EA had at this time, So where to see the error log for EA ?
Please do let me know for any inputs on the same.
Sunshine
  • Its the results that count
Re: Publish as HTML don't work in EA 14
« Reply #1 on: June 11, 2018, 01:38:13 pm »
Using EA V14 Build 1421 I managed to generated HTML okay from my model (eap). However I did observer it seemed to take longer than it used to but not 100% sure why.
If you are using and EAP file then perhaps try doing and integrity check. In the past I've discovered Doc Generation failed due to integrity issues which when fixed allow the doc generation to work okay. So I assume it might work the same way for HTML generation.
Happy to help
