Author Topic: Star Schema / Dimensional Database  (Read 4493 times)
lfgcasey
« on: June 08, 2018, 09:49:44 pm »
I see this in the Q&A section of several Database Engineering Webinars:
Q: Does Enterprise Architect support dimensional models?
A: No. Enterprise Architect supports physical data modeling for relational and geospatial databases.
Is this still true? If so, how would one go about modeling a data mart implemented using a star schema?
Richard Freggi
Re: Star Schema / Dimensional Database
« Reply #1 on: June 08, 2018, 10:42:41 pm »
*Drops monocle*
I thought star schema is just a style of schema implementable in any relational database?  Should be OK unless you need to forward engineer to a RDBMS that EA does not have DDL generation for
SamSepi0l
« Reply #2 on: June 08, 2018, 11:23:47 pm »
Richard, you are right.
Although star schema is a methodology and can be implemented in any relational database, I've seen in other data modeling tools that you can define your data model as a dimensional model, this allows you to identify the tables as fact or dimension and also allows you to maintain the data lineage.
I believe that's why in the answer posted by lfgcasey says "Enterprise Architect supports physical data modeling for relational...", but at the end I see that EA does not support dimensional models.
