Author Topic: Add transparency control to undocked (diagram) window  (Read 4337 times)
Uffe
« on: June 11, 2018, 06:20:27 pm »
Hi all,
Here's a left-field one.
When working with multiple projects and moving models between them, being able to quickly compare two instances of the same model is useful.
One way of doing this is to start two EA instances, undock the same window in both of them, align the two windows pixel-perfect one on top of the other, and then alt-tab between them looking for anything that "blinks". This is an obvious approach when working with diagrams, but really it works equally well with any type of window (properties, project browser, element browser...).
This type of visual comparison would be simplified by the ability to transparentifize the windows. That's a word. You could then just undock one, make it transparent and move it on top of the other, still-docked window; or you could undock both, make them both transparent, line them up and anything that shows up faint will only be present in one window, ie a difference.
/Uffe
