Author Topic: Help with collections  (Read 3906 times)
DanaMaxwell
« on: June 12, 2018, 01:48:34 am »
Hi All,
I have been struggling with using collections. I want to setup a temporary collection. The goal is to traverse the model via links but to make sure I do not put duplicates in my collection.
I am a VB newbie so I am sure this is something simple that I am not grasping but here goes.
I am trying to add an item to my collection but get the error "DanaTest.dummyCollection error: Object required: 'dummyColl', Line:29"
I have tried several variants to the code below with no luck.
code is below
option explicit
!INC Local Scripts.EAConstants-VBScript
' using a collection
' Related APIs
' Package API - http://www.sparxsystems.com/enterprise_architect_user_guide/12.1/automation_and_scripting/package_2.html
' Repository API - http://www.sparxsystems.com/enterprise_architect_user_guide/12.1/automation_and_scripting/repository3.html
sub dummyCollection()
   ' Show the script output window
   Repository.EnsureOutputVisible "Script"
   Session.Output( "VBScript Dummy collection " )
   Session.Output( "=======================================" )
   dim dummyColl as EA.Collection
   dim dummyEle as EA.Element
   dim contextObjectType
   contextObjectType = Repository.GetContextItemType()
   set dummyEle = dummyColl.AddNew("dummy1","Class")
   dummyEle = GetContextObject()
end sub
dummyCollection
Re: Help with collections
« Reply #1 on: June 12, 2018, 04:53:32 pm »
Hi Dana,
EA.Collection is not a "regular" collection type.
It can be used to iterate elements in EA (e.g. Element.Attributes) or to create new objects in EA (e.g. set myNewAttrbute = Element.Attributes.AddNew("attributeName", "string))
You cannot use it as a general purpose collection type.
Instead you can either use an array (which is often annoying since it has a fixed size) or use a .Net ArrayList.
To create a new ArrayList use:
dim myList
set myList = CreateObject("System.Collections.ArrayList")
