Author Topic: Changes to model not saved  (Read 3434 times)
mario1122
« on: June 19, 2018, 08:17:21 pm »
Hi all,
I'm using SQL server as repository for project file.
After project is created and then reopened changes are not persisted.
Tried with changing element note. Adding new package/element is persisted.
After change is done and project is reloaded - change doesn't exist.
I'm using v14.
Is there any issue with editing or I'm doing something wrong?
Thanks in advance.
« Last Edit: June 19, 2018, 08:19:44 pm by mario1122 »
Re: Changes to model not saved
« Reply #1 on: June 19, 2018, 09:52:38 pm »
I haven't seen such a behavior before, and I use SQL server repositories all the time (also with v14).
Are you editing the notes from the docked notes window (automatic save) or from the properties dialog (only save upon clicking OK)
If it looks like a bug that you can reproduce don't hesitate to send in a bug report
