Author Topic: [Warning] DAO.QueryDef [3296] Join expression not supported.  (Read 13252 times)
nopa
I encountered a problem while trying to work with Scenario Testing feature in EA.
This is how I got to the title problem:
a) Firstly, I created Test Case and inside Test Scenario (Structured Specification -> Basic Path).
b) Secondly, I made External TestCase.
c) I tried to change Test Scenario in generated by EA External TestCase, specifically in UseCase object: result was title error/warning.
So I have few basic questions:
1) Is it possible to change something in automatically generated External or Internal TestCase?
2) If it is possible then what I am doing wrong?
3) If it is possible, does it also update origin Test Case Scenario?
4) Is it correct way at all to create Test Scenarios?
Thanks in advance, any hints or tricks will be appreciated.
BR
Natalia
Re: [Warning] DAO.QueryDef [3296] Join expression not supported.
« Reply #1 on: June 22, 2018, 09:17:51 pm »
What is the query you try to execute? Or does that happen with a "normal GUI operation"? In the latter case you need to report a bug (link below in the Support section).
nopa
« Reply #2 on: June 22, 2018, 09:40:15 pm »
Normal GUI opearation, when trying to save Test Case Description.
« Reply #3 on: June 23, 2018, 08:15:35 am »
In that case, as said: report a bug.
