Author Topic: EA V14 Crashes repeatedly under Windows-8  (Read 3692 times)
PJK
  • Transmisi me sursum, Caledoni
« on: June 23, 2018, 03:18:03 am »
I am experiencing repeated crashes of EA V14 (latest build 1422) when working with profiles and MDGs. For example:
- Select an existing UML Profile in Resources window
- Import profile – overwrite:
- EA V14 crashes with a "...Tool has stopped working" message
No additional information. This also happens when importing an MDG into the model.
Repeating the same steps after relaunching the application usually works, so I suspect some sort of memory leak.
Cheers, Phillip
Suresh Jayakumar
Re: EA V14 Crashes repeatedly under Windows-8
« Reply #1 on: June 27, 2018, 10:49:16 pm »
Yes,I did faced the same. However,before shifting(while importing) the Profile or MDG just close and open the eap,so that you wont get stuck in middle of work.
