Author Topic: Nesting templates / Filtering on child-elements  (Read 4006 times)
Bandit
« on: January 31, 2012, 06:24:31 pm »
I've googled & searched doco's forums etc. but can't find anything that helps me on this one... assuming I'm searching for the right stuff.
Basic scenario is we have a bunch of use cases & we're trying to generate a detailed use case spec via an RTF doc. All works like a charm; normal course, conditions etc. look beautiful; but we're having trouble including just the actors.
We're trying to include the actors by finding elements connected to our use case. Thus we're using the "Connector"->"Source"->"Element" sections (& target->element) to try to get a dump of all the actors that "Use" each use case. Which works... but we also get all other connected elements such as other use cases which invoke or are invoked, extend etc.
This is what we're getting:
Use CaseUC001: Make Coffee
PreconditionsVictim is experiencing stage 2 caffeine withdrawals
Scenarios1. Victim desperately grabs coffee beans from cupboard
2. ...
Post conditionsMeltdown averted
ActorsVictim
UC002: Fervently Steam Milk
UC003: Add too much sugar
UC004: Attend Coffee Addicts Anonymous
What we're trying to get rid of are the struck through items which we're retrieving using the aforementioned connectors approach. We want the Actors section to only include the Victim, not all connected elements.
Does anyone have any words of wisdom to impart?
I was hoping we could do something like:
a) Add filters to child elements / sections ... eg. add a filter on the "Connector" section so it only retrieves connectors that are of the "Uses" type, or where the source element type is an actor or something?
b) Nest a template?? eg. create a template which is designed only to handle connectors, so we can add appropriate filters in the document properties of that child template; then drop that template into the "Actors" portion of our parent template in between the "Connector" section tags??
Either method will open up a new world of power & flexibility...
Surely this has come up before? *Fingers crossed*
Cheers,
Bandit
« Last Edit: January 31, 2012, 06:28:51 pm by Bandit »
Bandit
Re: Nesting templates / Filtering on child-element
« Reply #2 on: February 01, 2012, 03:07:36 pm »
Thanks Simon, I'll take a squiz & see how I go.
