Author Topic: "Get All Latest" does not get all from latest packages  (Read 7675 times)
ngong
« on: June 24, 2018, 09:04:13 pm »
EA-SCC(-PTC) version control link:
Built an .eap file with the master package.
Issued "Get All Latest" - for 44 sub-packages, nesting depth is 3: master - view - package
Ran a query to find "External References", that is, missing links between elements in those packages: found more than 50.
Because I know, all the links shall be there I ran "Get Latest" on views: EA tells me that they are "up to date", but I checked "Force reload from XMI".
Forcing reload of one view solved 4 links, forcing reload of the other view solved the rest.
But not all missing cross references are related to connections: on some component diagrams components are missing. Force reloading of the containing package solved this. But how to find all diagrams missing elements, supposed to be there?
« Last Edit: June 24, 2018, 09:38:57 pm by ngong »
Rolf
ngong
Re: "Get All Latest" does not get all from latetest packages
« Reply #1 on: June 24, 2018, 09:28:01 pm »
more details to the problem:
I lost several weeks of work and - that's worse - reputation in modeling by rolling back to older versions and manually had to re-enter change requests.
On check-in I used to use the window "Missing Cross References" too optimistically. It changed my model silently.
Currently I hope to survive and keep my model consistent in the following way - which is far not acceptable in the long run:
  • When I check out a package, immediately I try to check it back-in again. I cancel that check-in anyway.
  • If I get the window "Missing Cross-References" I also undo the check-out
  • I have to analyse the situation prior to try to check-out the package for change again
and ...
  • "Get Latest" on contributing packages. I can find the contributing packages by double clicking the count of missing cross references. A list of xmi:id appears.
    The xmi:id point to elements owned by contributing packages. How to identify the elements from their xmi:id is another story.
  • But: Now I never click "ok" in "Missing Cross-References" unless I exactly know what they are about.
  • Deleting the links by unchecking, or leaving them in - either may violate my model.
« Last Edit: June 24, 2018, 10:26:00 pm by ngong »
Rolf
