Author Topic: EA1421 - "Insert related Elements"- missing objects  (Read 6605 times)
marku
« on: June 26, 2018, 02:09:32 am »
Hi
I check it in 1421 and 13.
In the 13 (on the same objects) it's works ok, But i n EA 14:
1. I've Application components (from Archimate) connected witch each other (different relations- InformationFlow, assignment, abstraction), and artifact
2. I'm putting one application Component on the new diagram
3. I'm trying add (from Insert Related Elements) only other ApplicationComponent (from frame "Element types"). Unchecking others, "Refresh" - and list under are empty. I'm checking all elements type in frame- but still list are empty
(When I do it  in frame "Connector Type"- are this same effect- empty list object to insert)
When I do it  in EA 13 - it's work
VKN
Re: EA1421 - "Insert related Elements"- missing objects
« Reply #1 on: June 26, 2018, 10:02:12 am »
Try it using EA 1422 (EA 1421 have some issues)
or
try un-checking the option Strict Connector Syntax
http://www.sparxsystems.com/enterprise_architect_user_guide/14.0/user_interface/links.html
marku
« Reply #2 on: June 26, 2018, 05:41:09 pm »
I disable this option- still doesn't work.
Later I'll check in 1422
Guillaume
    • www.umlchannel.com
« Reply #3 on: February 19, 2019, 11:21:33 pm »
I got the same issue and thought it was an Archimate bug since it worked with UML classes.
Then I found that the Archimate 3 was disabled with the perspectives -> showing all perspectives fixed the issue!
Guillaume
