Author Topic: Drag and drop for external files  (Read 5769 times)
« on: June 28, 2018, 03:45:25 pm »
The Help says:
On a diagram to a file
To create a hyperlink on a diagram to an external file, simply click on the file in a file list (such as Windows Explorer) or on your Desktop and drag it onto the diagram.
A short context menu displays with two options - 'Hyperlink' and 'Artifact'. Click on the 'Hyperlink' option to create the hyperlink on the diagram.
The link is effective immediately, and you can right-click on it to add or change properties as necessary.
Files of most types - including .sql and .ddl - are opened within the appropriate Enterprise Architect code editor.
I tried to drag a number of different types of files onto a diagram.  All I got was the "No go" glyph.  What am I doing wrong?
TIA,
Re: Drag and drop for external files
« Reply #1 on: June 28, 2018, 04:01:43 pm »
Not sure, it seems to work fine for me.
Is your diagram locked somehow?
matthew.james
  • Am I supposed to say something here ... ?
« Reply #2 on: June 28, 2018, 04:23:36 pm »
Also worked for me (using a .pdf), v14.0.1420
« Reply #3 on: June 28, 2018, 04:25:35 pm »
I was trying it on our corporate SQL Server repository with User Security enabled (but diagram editable).  I've now tried it on an unsecured .EAP file and a .EAP clone of the Corporate repository, they both work.  I can't get at the Corporate Repository, while I'm on the bus, but I'll try later.
Thanks for the pointer.
[Edit: Rebooted system and restarted EA on the Corporate repository.  All good now.  I noticed EA was in a funny state previously (it seemed to lock up the diagram while demonstrating Virtual Connector Ends - so maybe that was the reason]
« Last Edit: June 28, 2018, 05:35:53 pm by Paolo F Cantoni »
