Author Topic: Code generation file per class model instead of file per class  (Read 3170 times)
camel2
I've got a question on code generation: Usually you would generate one or two files per class, but I would like to generate one file for all classes in a class model, is that possible? Thanks in advance!  :)
Nizam
  • Prolab Moderator
  • Model Sharing - Simplified
Re: Code generation file per class model instead of file per class
« Reply #1 on: July 02, 2018, 08:45:00 am »
You can, just set the filename for all classes as same, and all classes will be generated into one (but why?)
