Author Topic: Sequence/Interaction Diagram not getting documented in Use Case Template  (Read 10238 times)
Kartik
I've a model with use cases and while generating document I'm using the Use Case template , it generates everything except Sequence Diagrams . How do I generate them?
Hi
Please check whether you've included Diagram Section in the defined templates and also in the Diagram properties under the Diagram tab -> Document Generation Options check whether Exclude image from documentation has enabled , if so please disable and re generate the document.
Kartik
Those boxes are unchecked . If it helps the template prints the child element title but the sequence diagram under it is not printing.
Kartik
Btw how do I know which is an element /  child element . Is there a way to map one is to one by looking at the Project browser & document template ?
