Author Topic: Generated by EA word document doesn't contain highlighted text from Notes tab  (Read 4136 times)
redeer
there is need to see highlighted text from Notes tab in generated by EA word document.
I see HTML formatted tags in EA, but somehow they are lost in word doc.
Only bold text has seen in a generated word document.
EA version: 13.3.1351.
1. Notes tab example:
2. Template example:
3. Tried Use style defined in template for Notes check-box,- didn`t help.
That's will be great if such the possibility (to see highlighted text in a generated word doc) exists.
Hi redeer
Have you used any style sheet in your template ? Because by default the highlighted text will be generated as its in the notes Tab .
« Last Edit: July 13, 2018, 10:25:47 pm by Arshad »
redeer
Hi Arshad,
you are right, without any of templates the highlighted text generated as in the Notes tab.
So, for now, there is an open issue how to recognize which one of templates is "wrong" and what exactly should be changed.
Do you have any idea?
Thank you!
