Author Topic: EAP 14.0 Build 1422 Display of Element inherited Part/Properties are not correct  (Read 4065 times)
balu
the functionality to display inherited element parts/properties has several bugs.
1. In the Menu the button Parts/Properties is not visible
Right-Click on a Element with enherited parts/properties and Feature & Properties then only the fields Interactions Points and Set Properties Values are appearing.
Its necessary to click at Interactions Points to reach the tab for Parts/Properties.
Please add all possible Tab selection into the previous Menu to select and find the requested function faster. The finding in the former version 12 an 13 was easier.
2. The inherited Parts/Properties are not visible in the menu.
When you are setting a new element to complex type element (via Advanced --> Set Property Type) with enherited parts/properties in an other diagram then then its not possible to see the parts and properties in the table. The functionality with parts/properties appears correctly when you copying the element type into the new diagram.
Its also still working after deleting of the element type in the diagram. Remark: Its only working without saving the diagram. After saving the diagram the parts/proberties are becoming invisibel in the menu. In the former versions 12 & 13 it was working correctly.
The displayed elements are appearing on the wrong position below the element and not in the element.
3. Names for displayed enherited parts/properties are beginning sometimes with an ^. Sometimes these ^ appears and sometimes not.
« Last Edit: July 17, 2018, 11:39:33 pm by balu »
I wouild recommend that you make an official http://www.sparxsystems.com/support/forms/bug_report.html
