Author Topic: EA 14 Build 1422 CSV Import/Export Specification are deleted by EAP  (Read 5057 times)
balu
The Program is deleting created CSV Import/Export Specifications when you try to modify it.
Delete was not pressed and there is warning.
This is really frustating!
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
Re: EA 14 Build 1422 CSV Import/Export Specification are deleted by EAP
« Reply #1 on: July 18, 2018, 07:42:45 am »
Be sure of clicking "New" button before creating a new specification. Sometimes you think you are working on a new spec but the last thing you did was opening a previously created spec, so when you write the name of the spec and edit the rest of the spec, you are really updating the opened spec. I've used it in version 1422 with success.
Sunshine
  • Its the results that count
« Reply #2 on: July 18, 2018, 08:00:35 am »
Interesting I'm using V14 B 1422 but when I edit a CSV Import/ Export Specifications it works as expected and the specification is modified and not deleted like you are experiencing
I'm using it on a SQL Server repository on a Windows 10 Pro Platform.
Would you care to share
a) the steps you take when experiencing the deletion
b) your environment and repository technologies
Happy to help
