Author Topic: List the attributes of the element  (Read 7638 times)
medina
« on: February 03, 2012, 07:21:33 pm »
I was wondering how I can make a stereotype list the attributes it contains. I have looked in shape script but can't find anything, or is it something i need to add in the profiles diagram for my MDG?. Would really appreciate the help!
Re: List the attributes of the element
« Reply #1 on: February 03, 2012, 10:08:29 pm »
Ehrm - what?
medina
« Reply #2 on: February 03, 2012, 10:43:24 pm »
sorry i meant that i have made a stereotype and this stereotype has attributes that i have added. And i want these attributes to show as a list in this stereotype. Like this image
http://www.sparxsystems.com/enterprise_architect_user_guide/images/importtablesdiagram.png
« Reply #3 on: February 03, 2012, 11:07:27 pm »
(meta) attributes on stereotypes will result in tagged values in on the actual elements.
« Reply #4 on: February 03, 2012, 11:25:46 pm »
Geert is right. If you want some kind of default attributes to appear then you need to either use templates (I haven't really used that yet). Or you write an addin which catches element creation and adds attributes.
« Last Edit: February 03, 2012, 11:26:20 pm by qwerty »
medina
« Reply #5 on: February 08, 2012, 02:02:35 am »
Hi
No, I do not want to make default attributes automatically to be added to the element.
I just want the Attribute Compartment to be made visible. So if the user adds an attribute, then the attribute (and its value) is to be shown in the compartment - as in this picture.
I'v tried to add the styleex and pdata to the Diagram Profile (HideAtts=0;) but the attribute compartment still doesn't show in the element, (as in the picture above).
I've also turned on (=1) all the _Attxxx listed on Supported Attributes
Maybe it has something to do with the Shape Script?
Using the example on Example Scripts
shape main {
       rectangle(0,0,100,100);
       addsubshape("namecompartment", 100, 20);
       addsubshape("stereotypecompartment", 100, 40);
       shape namecompartment {
               h_align = "center";
               editablefield = "name";
               println("name: #name#");
       shape stereotypecompartment {
               h_align = "center";
               editablefield = "stereotype";
               println("stereotype: #stereotype#");
with all the avail properties listed in Display Element Properties
I STILL cannot make attributes visible on the element.
Please help
[size=18]tl;dr[/size]
I'm looking for something like
[size=15]println("attribute: #ATTRIBUTE# #ATTRIBUTE.NAME# #ATTRIBUTE.VALUE#");[/size]
« Last Edit: February 08, 2012, 02:09:27 am by medina »
« Reply #6 on: February 08, 2012, 02:49:32 am »
Check your diagram properties and turn on attribue visibility.
medina
« Reply #7 on: February 08, 2012, 04:16:11 am »
I've done that. No luck.
I'm pretty sure(?) it's a shape script problem.
(hence the pseudo example... println("attribute: #ATTRIBUTE# #ATTRIBUTE.NAME# #ATTRIBUTE.VALUE#"))
Since using the "default" UML-Class element is working ("working"=showing its attributes as in the picture above) in my diagram but my own made element does not (even thou it HAS attributes).
So what is the Shape Script code for the Class element? anyone?
« Reply #8 on: February 08, 2012, 05:07:36 am »
A shape script is define only and only for classes with stereotypes since the shape script itself is part of the stereotype. Check Settings/UML/Stereotypes for any shape scripts.
« Reply #9 on: February 08, 2012, 08:46:48 am »
It is a limitation of shape scripts that you cannot list an element's attributes or operations.
