Author Topic: Any tool for converting class model to database model?  (Read 5287 times)
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« on: July 20, 2018, 03:49:49 am »
Do you know any feature or plugin that allows, given a class model (classes with attributes and relationships), convert it to a database model of classes (classes stereotyped as <<table>> with columns and foreign keys)?
We don't have a ERD model, but a simple class model.
Re: Any tool for converting class model to database model?
« Reply #1 on: July 20, 2018, 05:13:15 am »
How about EA's DDL script?
And (IIRC) there's an add-in called DBMode which is probably worth a look.
« Last Edit: July 20, 2018, 07:15:22 am by qwerty »
Sunshine
  • Its the results that count
« Reply #2 on: July 20, 2018, 06:40:02 am »
Look at DDL Transformation built in to Sparx EA.
You can tweak the transformation if it doesn't suit you exact needs too.
http://www.sparxsystems.com/resources/mda/ddl_transformation.html
Happy to help
Nizam
  • Prolab Moderator
  • Model Sharing - Simplified
« Reply #3 on: July 20, 2018, 02:36:33 pm »
You can use DDL or write a script to stereotype the objects, attributes, and connectors
