Author Topic: HTML export with more than one root node  (Read 5137 times)
siaccarino
« on: July 24, 2018, 05:10:05 pm »
I have a setup (EA 12) where architecture, design and requirements are handled in one database in separate root nodes.
Now I want to setup a complete HTML dump on nightly base for documentation.
Unfortunately I did not found a way to dump more than one root node - I can only dump separately but then all links across different root nodes are vanished.
Is there a way to dump the whole DB into one HTML model?
best regards,
Silvio
OpenIT Solutions
Re: HTML export with more than one root node
« Reply #1 on: July 24, 2018, 05:23:00 pm »
I believe you can create a virtual document that includes content from multiple root nodes. Search the help on virtual documents / html export for further details.
Jon.
siaccarino
« Reply #2 on: July 24, 2018, 06:11:19 pm »
Thank you - that does the trick!  :)
