Author Topic: SOLVED: Connector from custom profile rendered as Profile::Stereotype  (Read 4442 times)
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
I have a MDG based on a profile containing only connectors. When I create a new connector between elements, the stereotype in the connector is shown as <<MyProfile::MyStereotype>> instead of only <<MyStereotype>>.
Previous versions of MDG (a year ago) had generated <<MyStereotype>> connectors. It is supposed we have not made any change in the profile definitions, but now the connectors are generated as <<MyProfile::MyStereotype>>.
Any ideas what could be changed? (I've already checked any custom stereotype in the UML Types window.)
« Last Edit: August 06, 2018, 10:52:12 pm by Arquesoft »
Re: Connector from custom profile rendered as Profile::Stereotype
« Reply #1 on: August 06, 2018, 03:53:52 pm »
Have you run a file comparator (such as BeyondCompare) over the two versions?  Where things break for us, we carefully compare the working vs non-working version and try to "suss out" what broke.
« Reply #2 on: August 06, 2018, 04:05:31 pm »
Try it on a new model with no other MDG's or add-ins enabled.
« Reply #3 on: August 06, 2018, 10:15:29 pm »
The problem is the size of the model. It is a DMBS based model and it is about 1Gb in size.
« Reply #4 on: August 06, 2018, 10:51:08 pm »
Great idea! I have just test it in a new EAP file and it works well. So, I rechecked the original model and I found some stereotypes (in UML Types) with the name "MyProfile::MyStereotype". So I just delete them and this solved the issue.
