Author Topic: EA data model  (Read 5967 times)
michielper
EA data model
« on: July 31, 2018, 08:04:46 pm »
Where do I find the complete EA data model? All tables and attributes that one can use in SQL queries.
peterc
Re: EA data model
« Reply #1 on: July 31, 2018, 09:51:16 pm »
Option 1 - the Automation.pdf guide in the PDF library (under Resources at the top of this page).
Option 2 - Change the extension of the EAP file (so long as you are using that format) to MDB and open it in Microsoft Access.
Re: EA data model
« Reply #2 on: July 31, 2018, 10:02:47 pm »
Reverse engineer an EA model into EA.
Sunshine
  • Its the results that count
Re: EA data model
« Reply #3 on: August 01, 2018, 06:48:50 am »
I've done what Geert recommends in the past and reverse engineered the repository to get a view of the database tables etc.
If you want to do queries you can use the search SQL Scratch pad built into Sparx EA or use MS Access for eap files or Visual Studio for SQL repositories.
However if you want to update stuff then its recommended you use the API and reference the automation documentation.
https://www.sparxsystems.com/resources/user-guides/14.0/index.html#automation
In addition Geert has also published a truck load of stuff on GitHub that can help with automation. Sorry don't have a reference for that at hand.
Hope that helps
Happy to help
Re: EA data model
« Reply #4 on: August 01, 2018, 10:30:36 am »
For what purpose do you need it?
Re: EA data model
« Reply #5 on: August 01, 2018, 03:51:26 pm »
You can find my Github stuff here: https://github.com/GeertBellekens
Guillaume
    • www.umlchannel.com
Re: EA data model
« Reply #6 on: August 01, 2018, 04:16:56 pm »
Inside EA ebook will provide all the details you're looking for. I recommend to purchase Scripting EA.
https://leanpub.com/InsideEA
Guillaume
