Author Topic: Generate documents based on element tag  (Read 4192 times)
« on: August 03, 2018, 11:29:27 am »
Has any generated document by using tags?
I've got the idea of retricting the elements in a document by generating a document using tagged values.
For example the model document only generated from elements where to tags are specified, or one of a specific set of tags is applied to the element?
tia
Simon
Re: Generate documents based on element tag
« Reply #1 on: August 03, 2018, 04:07:02 pm »
You can add a filter in the template properties to restrict the tagged values.
Alternatively you can also use a search on a model document to select the elements you would like to report.
