Author Topic: Transition Conditions in EA14  (Read 3640 times)
Arne Lang
« on: August 03, 2018, 03:25:38 pm »
Hi All,
I have two issues with the transition conditions in statemachine diagrams. The first issue is that, seemingly random, the names for signals are not consistent with the displayed names. The signal are correct in properties. After opening the properties the signals are shown properly.
The second issue is that for transition that have no signals and only guards as placeholders, those guards cannot be properly removed which means that deleting the Guard in the properties does NOT remove those guards in the diagramm. Even after opening the properties of the transition, to check if the guard is removed, does not delete the last Guard that was written, from the diagramm.
I use EA version 14 with build 1421 (Corporate Version)
