Author Topic: How can I add a table with content inside a UML Use Case Diagram?  (Read 4421 times)
raffaele.garofalo
Hi, I have a set of UML Case Diagrams and in our documentation we are used to decode each use case and add a Legend table after the diagram where we document the meaning of each Use Case.
With Visio I have multiple options to achieve this but with EA I don't know if it's even possible.
I don't want to draw the table by hand, so is there any way that I can add a custom table (With Rows and Columns and content) into a Diagram?
PeterHeintz
Re: How can I add a table with content inside a UML Use Case Diagram?
« Reply #1 on: August 07, 2018, 11:48:16 pm »
What do you put in your tables?
The use case scenarios, right?
Best regards,
Peter Heintz
raffaele.garofalo
« Reply #2 on: August 07, 2018, 11:52:46 pm »
Yes, the Use Case scenarios
PeterHeintz
« Reply #3 on: August 08, 2018, 12:01:39 am »
EA/UML does not really have an “any Purpose” table.
However you have several options.
-Put you scenarios as natural language under Properties/Rules/Scenarios/Description
-Put you scenarios as sequential steps under Properties/Rules/Scenarios/Structured Specification
-Create e.g. sequence- or activity-diagrams representing the scenarios and associate those e.g. by <<refine>> association to the use case.
Best regards,
Peter Heintz
Richard Freggi
« Reply #4 on: August 08, 2018, 10:46:25 am »
Tagged values are an excellent way to add pre, post conditions, descriptions, scenarios etc.; and very easy to export to Excel (csv files).  Sparx documentation explains how to use them.
matrices can be used to list actors by use case.
PeterHeintz
« Reply #5 on: August 08, 2018, 06:12:57 pm »
Yes, Tagged Values are intended to extend too what is not there, but this stuff is already there at least for use cases. So, no need to use tagged values.
Best regards,
Peter Heintz
