Author Topic: Displaying Properties of the ERD tab of an attribute or entity.  (Read 3115 times)
DanaMaxwell
I find it a little bit puzzling that using the Publishing function with the Data Model template that it does not include the properties defined in the ERD tab of an <ERD_Entity> or <ERD_Attribute>. I can only assume this template is meant for a different type of model?
Is there no template meant to produce a conceptual database design report from an ERD Model?
Thanks for your help.
Sunshine
  • Its the results that count
Re: Displaying Properties of the ERD tab of an attribute or entity.
« Reply #1 on: August 15, 2018, 07:06:04 am »
Think that template was aimed at logical and physical data models where entities have embedded attributes/columns. You know the other way to model data.
You'll need to create your own template for ERD. Its easy to do
Happy to help
