Author Topic: rich text in report not displayed correctly  (Read 3041 times)
ea_user
« on: August 15, 2018, 04:27:19 pm »
Hi All,
Has anyone dealt with this?
The 'Note' field of elements which has rich text are appearing in the report along with the tags like <li> or <ul>. Any setting to remove them from the report?
Re: rich text in report not displayed correctly
« Reply #1 on: August 16, 2018, 04:56:45 pm »
If you use regular templates (using insert field -> Notes) that shouldn't happen.
If you use an SQL or script fragment then you have to do something special for EA to recognize the field as "rich text".
In a script fragment you need to add an attribute to the xml element, in an SQL fragment you need to add .formatted to the name of the result field.
This is explained in the manual in more detail.
ea_user
« Reply #2 on: August 17, 2018, 08:45:42 am »
Thanks Geert. Appreciate your help!
