Author Topic: empty t_seclocks.EntityIF, what to do about it?  (Read 5484 times)
ngong
« on: August 23, 2018, 06:22:33 am »
Switched from .eap-files to SQL Server based storage of EA model.
Transfer to .eap-file worked fine till today.
I got the message: "An error has occurred: DAO.Recordset  [3314], The field 't_seclocks.EntityID' can't contain a Null value because the Required property for this field is set to True. Enter a value in this field. [Select * from t_seclocks], Field: locktype. Press OK to continue to next row (this record will be lost). Cancel to abort
Ok, I entered the SQL query and got 5 lines as a result. In one of them the field below the column heading EntiyID is empty. Guess that causes the problem. (I do not know how it got there, I was using EA heavily, but interactivily only.)
What shall I do about it? Transfer the result back, so that that record disappears from table t_seclocks? What will be the consequences?
Rolf
Re: empty t_seclocks.EntityIF, what to do about it?
« Reply #1 on: August 23, 2018, 08:02:47 am »
Run a consistency check.
ngong
« Reply #2 on: August 23, 2018, 04:56:37 pm »
Hi, qwerty: I forgot, I ran consistency check and it led to "No Problem".
Rolf
« Reply #3 on: August 23, 2018, 05:16:20 pm »
You could run (via Repository.Execute)  SQL like
DELETE FROM t_seclocks WHERE EntityID IS NULL
Make a backup first.
