Author Topic: Use script to transfer traceability links from 1 requirement to another  (Read 5394 times)
NickBeaumont
I am importing new requirements into EA (V13) that have a different numbering structure from those already existing in the database.
I must write a script (VBScript or JScript) that:
- analyses the current traceability,
- compares the old and new requirements from an external file,
- and then transfer the traceability from the old requirements onto the new requirements.
The traceability is between a requirement and a EA constraint.
P.S. I'm new to Scripting so I need an idiots guide.
However I know EA very well.
Re: Use script to transfer traceability links from 1 requirement to another
« Reply #1 on: August 24, 2018, 01:46:58 am »
AFAIK my Scripting book is the only dummies guide.
Helmut Ortmann
« Reply #2 on: August 27, 2018, 04:57:18 am »
I can recommend qwerty's book.
Additional approaches:
- EA ships with a lot of example scripts (VB, JScript, JavaScript)
- EA Automation interface (Java, C#, & more)
- Add-In, all languages which support the Microsoft COM interface
My personal approach is C# and Add-Ins for more complex situations because of type checking and the possibility to handle complex solutions with a user-friendly GUI.
Every approach has its pros and cons.
Best regards,
Helmut
« Reply #3 on: August 27, 2018, 05:43:35 pm »
If you need more samples check my github repo: https://github.com/GeertBellekens/Enterprise-Architect-VBScript-Library
