Author Topic: add in missing exception when i try to register my add-in with regasm.exe cmd  (Read 5754 times)
bakawakalaka
Hi, I try to make add-in that i can install at diferent computers
When I registry my add-in using prompt command "regasm <full dll patch> /codebase" it's work fine.
But if I register using same cmd command then EA just dont see my dll
I know that this problem connected with how regasm registry key of my dll but i cant find diference in use both cmd and prompt
Helmut Ortmann
the best thing I know to find installation issues regarding EA Add-Ins is:
https://community.sparxsystems.com/community-resources/772-ea-installation-inspector
it saved me a lot of work.
Best regards,
Helmut
EXploringEA
Further to Helmut's post - I have a newer version of the tool which can provide additional information e.g. Registry Tree view which may help.  For details and download link go to http://tools.exploringea.co.uk/index.php?n=EaInspector.Development.
EXploringEA - information, utilities and addins
bakawakalaka
Helmut
Well, I already using EA Instalation inspector (and also I see vb code on github of this project) but I only found that prompt regasm command and cmd regasm command work different.
EXploringEA
Can you give a link to github repository?
Anyway, now I just saved repository HKCR keys Before I did using prompt regasm command and After. Then I compared both files. Finaly I get .reg file that contains all keys that need to install. It's work fine at my computer. Tomorow I will check it on other computers.
EXploringEA
Hi
Github for Installation Inspector is on the EXploringEA site and is https://github.com/EXploringEA/EAInstallationInspector
(Note: the code on GitHub is for V4 - not the current development release)
Regarding you problem can you post the contents of your cmd file that you have found doesn't work and I can take a look.
Regards
Adrian
« Last Edit: August 29, 2018, 03:52:32 pm by EXploringEA »
