Author Topic: VBScript view variable contents  (Read 10082 times)
Abett
« on: August 30, 2018, 11:52:08 pm »
I've created a variable within a script and I wish to be able to view the information stored under that variable, is there a way to do that?
Re: VBScript view variable contents
« Reply #1 on: August 31, 2018, 02:23:05 am »
If you debug the script you can use the "Local Variables" window to inspect these.
Alternative is to print them using Session.Output
David Rains (bioform)
« Reply #2 on: September 03, 2018, 09:41:21 am »
And if you need that value within your model, you could store that it in a tagged value associated with the element or association it has some context to...
I often use tagged value as containers for metadata that is derived via scripts an example might be the "completeness of the specification" of one of my elements... (say from a scale of -1 to 4 or an enumeration of n/a, not started, incomplete, acceptable, completed; then using a shape-script altering the elements color or other adornment visually to indicate the status...)
