Author Topic: Where can I find the <<navigate>> conncector?  (Read 5222 times)
jaimecerda
« on: September 04, 2018, 08:00:48 am »
Hi, I use the <<navigate>> connector when creating associations between Screen elements by using the small arrow icon next to the elements.
Now for special reasons I want to use that same connector between other elements, understandibly, using the same arrow icon will not show the Navigate connector.
I can't find the toolbar where the Navigate connector exists.  I think i've searched all toolbars.
Currently what I do is create an associaction, and change the stereotype to EAUML:Navigate and then set the connector direction to make it show an arrow.  This process is tedious and would be simple if I could use the Navigate connector from the toolbar.
Does anyone know where it is (in which type of diagram)?
Thanks for any help.
-JCG
Re: Where can I find the <<navigate>> conncector?
« Reply #1 on: September 04, 2018, 10:49:17 am »
The EAUML::Navigate association doesn't appear in any toolbox. Perhaps you could look into creating your own custom toolbox. Until then, a tip to make your manual process less tedious is to switch on the ribbon|Start|Preferences|Links|Association default=source-->target option.
jaimecerda
« Reply #2 on: September 15, 2018, 07:05:48 am »
Thanks this can work!
Would be nice if in a future version the connector exists in a toolbox ;)
