Author Topic: Display interface connector in class diagram  (Read 3119 times)
Frederick.Brier
« on: September 05, 2018, 04:15:37 am »
When I drag an interface and a class that implements it into a class diagram, I would expect a connector between them. Class inheritance connectors are displayed. The implemented interface in the class is displayed. I found a forum post from 2007 http://www.sparxsystems.com/forums/smf/index.php/topic,6867.msg132561.html#msg132561 that mentioned an "Embedded Elements" context menu. However, searching the current v14 manual doesn't find it. What is the current mechanism to cause the realized connector to be displayed? Thank you.
Re: Display interface connector in class diagram
« Reply #1 on: September 05, 2018, 02:23:23 pm »
If the connector isn't showing on a new diagram, then it doesn't exist.
All connectors are shown on diagram by default.
You can also inspect the traceability window, or the relationships window to get a non-visual view of all the relations of an element.
