Author Topic: BizBok Value Stream model - change aspect ratio  (Read 3797 times)
McVeyIMR
« on: September 05, 2018, 11:39:02 am »
I'm using EA 14 to model Value Streams as per the BizBok guidelines. The Value Stream element that is provided in the toolbox has the ratio aspect fixed by default. This means that if I want to expand that element horizontally, the element also grows vertically. That is not the look that I want to achieve.
I've spent a lot of time searching how I can "unfix" the ratio aspect but have come up with nothing. In the interim I am substituting another element for the value stream element but this is not ideal.
Can anyone suggest how I could change the horizontal and vertical dimensions of the Value Stream shape independently of one another?
Thanks.
Re: BizBok Value Stream model - change aspect ratio
« Reply #1 on: September 05, 2018, 12:16:03 pm »
It appears that the BIZBOK value stream is an extended Use Case element. Try checking the option ribbon | Start | Preferences | Objects | Allow elongated use cases.
McVeyIMR
« Reply #2 on: September 05, 2018, 12:40:59 pm »
Thank you so much! That worked. I would never have found that option on my own.
