Author Topic: Use of @Element in QuickLinker  (Read 4795 times)
« on: September 10, 2018, 05:06:54 pm »
We can use the @Element (for example) in a QuickLinker entry to allow more generic relationships specification.  Here's one entry that works...
Class,,@Element,,,Class,,Nesting,Nstng,to,nesting¯,nesting¯,True,True,,True,(Nesting),0,,,,,
Any Class can be nested within any Element.
Since any element can be nested within another element (or package - which in this context appears to be an element) we thought we'd generalize it to:
@Element,,@Element,,,Class,,Nesting,Nstng,to,nesting¯,nesting¯,True,True,,True,(Nesting),0,,,,,
However, this doesn't work.  Should it?  If not, why not?
Reported,
Re: Use of @Element in QuickLinker
« Reply #1 on: September 11, 2018, 09:14:53 am »
I'd say the reasons why it doesn't work are implementation rather than a conceptual it shouldn't. Both the connector type and source element type need to be concrete metaclasses.
You can define a relationship like this using the metamodel functionality in EA 14.  (Define Metamodel Constraints)
« Reply #2 on: September 11, 2018, 10:48:20 am »
I can see the Connector type has to be concrete, but the source type?  Should I submit a bug report?
As to the metamodel functionality, we're trying to head toward that, but since Sparx don't provide an MDG reverse engineer facility, it's HARD!
Since we haven't really looked at it yet, does the new functionality create the same QuickLinker entries or not?  If so, then surely the problem still applies.
« Reply #3 on: September 11, 2018, 01:19:42 pm »
As I said, @Element in the source won't work for implementation reasons, not necessarily conceptual ones. EA needs the source type to be a concrete term.
The metamodel method for specifying relationships does allow it, but it works by expanding the three metatypes involved before feeding information to the quicklinker.
« Reply #4 on: September 11, 2018, 02:35:34 pm »
Thanks, I get it (at least the drift).
