Author Topic: Create Replica of a Design Master via CommandLine  (Read 4580 times)
sbleden
« on: September 10, 2018, 11:23:49 pm »
Hey Guys,
i just wondering if its possible to create a replica of an existing Design Master via the Command Line?
Greetings
Bastian
Re: Create Replica of a Design Master via CommandLine
« Reply #1 on: September 11, 2018, 12:58:08 am »
Bastian,
Stop right now and find an alternative for the replica mechanism.
This MS Access mechanism is shaky at best and it will come back to bite you sooner or later.
« Reply #2 on: September 11, 2018, 07:25:07 am »
I'd say: more sooner than later.
However, if you're sticky to that Mickeysoft stuff just go and google for "MS Access replica" since EAP is just that.
bpirk
« Reply #3 on: September 13, 2018, 04:54:38 pm »
Hey,
thx for the answers.
Is there another way, the work offline on the same eap file and merge it later?
Greetings
sbleden
« Reply #4 on: September 13, 2018, 05:28:00 pm »
Hey,
Greetings
sbleden
Hi, you can't really merge models, but you can use version control to work together in offline mode.
The difference is that you check-out a package for exclusive use. Until the package is checked in again, other people won't be able to edit that package.
You can connect a bunch of different version control systems, but the most common ones are SVN and TFS.
