Author Topic: Notification When an Element is Modified  (Read 5323 times)
SteveC
« on: September 11, 2018, 07:32:14 am »
Is anyone aware of how an add-in can be notified when an element is modified?
For example, I'd like to know when the user changes a tagged value of one of the elements. This would allow the add-in to check if it should perform any processing on the element based on the new tagged values.
Re: Notification When an Element is Modified
« Reply #1 on: September 11, 2018, 07:45:04 am »
There's a hook (EAOnContextItemChanges IIRC out of memory). But it does not report TV changes.
EXploringEA
« Reply #2 on: September 11, 2018, 04:49:49 pm »
I had this requirement sometime ago and used EA_OnNotifyContextItemModified but this doesn't let you know if this is due to a tagged value change.
Hence, my approach was to use EA_OnContextItemChanged to track the selection of an element, and take a copy of tagged values before any changes.  Then when ContextItemModified is triggered a check can be made to see if there is any difference for a tagged value.  Not ideal..
EXploringEA - information, utilities and addins
« Reply #3 on: September 11, 2018, 04:53:27 pm »
There is a (fairly) new set of events related to editing tagged values:
https://www.sparxsystems.com/enterprise_architect_user_guide/14.0/automation/tagged_value_broadcasts.html
« Reply #4 on: September 11, 2018, 05:25:21 pm »
Unfortunately, they are only relevant for AddinBroadcast tagged values.
But you could use them to force tagged value edits to go through your addin.
« Reply #5 on: September 11, 2018, 06:56:11 pm »
Ahh, too bad   :'(
Would be nice to have such a general "taggedValueModified" event thoug.
