Author Topic: Custom element label in EA with ArchiMate  (Read 11322 times)
TVereecken
« on: September 11, 2018, 11:51:14 pm »
I'm trying to apply a custom rendering to Archimate elements where the name of the element is in bold, the (business) domain of the element is presented below and finally the element type is put at the end.
For instance, an application component named Authenticator should be displayed as (instead of just 'Authenticator'):
Authenticator
Security
ApplicationComponent
Is there any way this behavior can be accomplished or approached in EA?
Re: Custom element label in EA with ArchiMate
« Reply #1 on: September 12, 2018, 12:55:14 am »
The simple answer is: no.
« Reply #2 on: September 12, 2018, 02:18:07 am »
I'm not sure that that is not possible, it depends on where it needs to get the business domain.
If you put that into a tagged value then I guess that should be possible. Getting it from the package or a related element might prove to be harder, although with the help of an add-in almost anything is possible, be it at the cost of performance.
Basically you would want to override the standard Archimate stereotype and write a shapescript that replaces the standard shapescript.
Put that into an MDG and deploy.
It not not the most simple task however. If you have never done anything like that you might want to seek help from an EA consultant.
« Reply #3 on: September 12, 2018, 05:38:56 am »
The problem is the bold face. There's nothing to set individual fonts via shape script.
« Reply #4 on: September 12, 2018, 08:58:01 am »
On a basic shape it looks something like this. (Note, the bold text for a subshape is EA 14.1 only)
shape main
layouttype="Border";
rectangle(0,0,100,100);
addsubshape("name","N");
addsubshape("body","CENTER");
shape name
bold="true";
preferredHeight=20;
h_Align="center";
print("#name#");
shape body
println("#TAG:Domain#");
println("ApplicationComponent");
TVereecken
« Reply #5 on: September 12, 2018, 05:06:31 pm »
Currently the business domain is simply included in the element name, we were thinking to move it to a tagged value.
Thanks for your suggestion. It does sounds like a non-trivial task to configure this.
We have been looking at your website - it's possible we might contact you for this (BE based).
TVereecken
« Reply #6 on: September 12, 2018, 05:07:48 pm »
shape main
shape name
bold="true";
preferredHeight=20;
h_Align="center";
print("#name#");
shape body
Thank you. We'll try to get this to work.
Sunshine
  • Its the results that count
« Reply #7 on: September 12, 2018, 07:01:12 pm »
Try this shape script as it draws the ArchiMate Application Component and will do what you appear to want.
shape main
layouttype="border";
defsize(90,70);
if(hasproperty("rectanglenotation","0"))
addsubshape("port","w");
addsubshape("name","n");
addsubshape("packagename","center");
addsubshape("stereotype","s");
shape port
preferredwidth=20;
scalable=false;
rectangle(-10,-10,10,0);
rectangle(-10,10,10,20);
shape name
//bold="true";
preferredHeight=40;
v_align ="bottom";
h_align="center";
print("#name#");
shape packagename
preferredHeight=20;
v_align ="center";
h_align="center";
println("#packagename#"); // Assume the package is domain then could use package name
shape stereotype
preferredHeight=20;
v_align ="top";
h_align="center";
println("#stereotype#");
decoration component
orientation="ne";
else
rectangle(0,0,60,100);
rectangle(-10,10,10,30);
rectangle(-10,50,10,70);
The quick way to get the result you are looking for is to create a stereotype in your model called "ApplicationComponent" which extends UML component.
You can create stereotypes via Ribbon Configure>UML Types
Stereotype Name:ApplicationComponent
Base Class: Component
Override Appearance: Shape Script radio button
Click Edit button and paste the script
Click OK button
Click Save button
Click Close button
Once that done create a ArchiMate V3 diagram then drag a Archimate Component on to it and change the stereotype from "ArchiMate_ApplicationComponent" to "ApplicationComponent"
Hope you can follow those instructions
If you find that helpful then a helpful vote would be appreciated.
« Last Edit: September 12, 2018, 07:19:36 pm by Sunshine »
Happy to help
TVereecken
« Reply #8 on: September 12, 2018, 11:40:17 pm »
*snip*
Thank you, we'll try it out.
I'd like to, but I don't see that option on the thread UI.. either I'm not seeing it or I don't have enough rights as a user, which is common for new users.
« Reply #9 on: September 13, 2018, 04:56:38 am »
It's the Helpful to the left under the poster's name.
« Reply #10 on: September 13, 2018, 02:30:35 pm »
I think you have to have at least 20 posts before you can vote.
