Author Topic: How to setup a RAS (Reusable Asset Service)? [solved]  (Read 6313 times)
Shegit Brahm
« on: September 12, 2018, 09:26:22 pm »
this RAS feature sounds nice. So my object is to find out - what is possible, which (technical) limits exist etc.
(Have EA Enterprise 13.5 at hand)
I started reading on Sparx' page to get started (setting up) http://www.sparxsystems.com/enterprise_architect_user_guide/13.5/model_repository/setup_asset_service.html
My problem starts in the second sentence of the first step (identify registry):
- The Registry server holds the Storages of the Reusable Asset Service.
- It will have been previously configured by your system administrator, to be accessed through a Cloud Connection.
Because - I am in that case the system administrator and - I struggle to find any "next" page what I need to do to get a "registry" up and running.
I have a server, where the Sparx EA service is running.
I can create a database (MySQL), initialize it as an EA repository.
Take the connection details, open an local EA on a client machine and connect. And model my way through.
So my first question is:
- Which components must be up and running to create a registry server? (And how do I connect to it?)
I am able to open the RAS view on my local EA, right now it is empty.
Than there is the second part:
http://www.sparxsystems.com/enterprise_architect_user_guide/13.5/model_repository/set_up_registry_password.html also notes that I should do it on the Registry Server
- How do I get there?
After anything is up and running, I guess this is more easy:
- Do I create a storage from my local machine? The part of "Create Storages" implies it.
Many thanks,
Shegit
« Last Edit: October 11, 2018, 01:14:29 am by Shegit Brahm »
Shegit Brahm
Re: How to setup a RAS (Reusable Asset Service)?
« Reply #1 on: October 11, 2018, 01:13:48 am »
Was easier than expected.
the "registry server" is nothing more than a simple EA cloud connection with a model stored as real DBMS instead eap.
That means:
  • set up a cloud based EA model.
  • have your second model at hand (with sufficient rights)
  • go to Publish -> (model Exchange) -> Reusable Assets-> Registry: select the EA model set up in first step
  • now you are connected to the central registry server
That said - I can't tell you right now the sufficient rights to do what inside RAS etc.
Assets can become what I create locally and "register"=export them into the cloud model.
And importing from cloud model creates local copies.
As far as I digged until now: GUIDs will be "central" at the cloud model and whereever you import from there, EA will (try to) set the central GUID.
Which implies: can't tell you now what happens if I have a local GUID for a different element and the import it from cloud.
Shegit
Graham_Moir
Re: How to setup a RAS (Reusable Asset Service)? [solved]
« Reply #2 on: October 11, 2018, 08:28:57 pm »
This is helpful Shegit.
It would help even more if you posted further to this thread as you work through the practical use of RAS
Shegit Brahm
« Reply #3 on: November 15, 2018, 11:40:33 pm »
    @Graham_Moir: thanks for your encouragement.
    I digged deeper and will post some major "ah"-moments.
    assets:
    • smallest unit: empty package
    • => package is general unit
    • => no single element can become an asset
    • latest version is the highest version number EA says - not always the newest
    • change an asset?  - make a new version!
    • merge: only from baseline (e.g. one asset version) into local model - there is partial / elementwise merge=import possible (local delete as well)
    • access different version: the dropdown does appear only if you know to look in the version column
    • same guid? - "crashes/ mixes up" more or less like an xmi import with same guid on different elements
    dependencies
    • will be treated as separat assets - and dependent version will be saved, too
    storage:
    • password(s) can be set - once all passwords are gone / never set => no new password(s) can be set
    • as long as you have access to a storage, you can easily copy it
  • lost password? guess this is the encrypted version (xmi export):
<code header1="dY1h8mpERIOE5cRGig3Leiq+RWBnsPe1BbwouUEf6TE=" header2="dY1h8mpERIOE5cRGig3Leiq+RWBnsPe1BbwouUEf6TE="/>
    be careful
    • you update two assets and the second is dependency of the first and you register new version of first asset?
      • please avoid using "use latest version in registry"
      • that would ignore your current local changes of second asset
      • untick it and register second asset with a new version from local project
      [li] take a look, if the "latest version" is really the newest - the dropdown has them in created-order
    BUG
    • the version name permits these characters <>;:“/\|‘,?*
    • well, it checks in advance to registering on these only
    • it DOES NOT check on any non-english characters BEFORE saving into registry server
    • it does realize this error few seconds later while the storage got reloaded to show changes
    • that crashes entire registry server regarding read and write (all storages)
      • I was lucky and could just delete the storage in registry server ea model (because nothing else was in it)
    HTH, Shegit
    « Last Edit: November 16, 2018, 12:33:28 am by Shegit Brahm »
