Author Topic: Scripts not running and console closed automatically (Spanish version)  (Read 2985 times)
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
If using Spanish version, the script debugger doesn't work (ver 13.5). You can test it easly openning the script window, Console tab and writing: !JS. The expected behavior:
>!JS
JScript console opened
The actual behavior:
>!JS
console closed
So, it is impossible to run any script. In order to work, we had to install the trial version in English and it worked. Tested in several computers with the Spanish version with the same result.
