Author Topic: UAF ERROR:"Model Template Pattern failed to load.  (Read 11822 times)
harold.lee
« on: September 14, 2018, 08:47:35 am »
I just installed Ultimate 14.1, but when I select the UAF profile for wizard to build, I get following error, "Model Template Pattern failed to load. Ensure the selected template file is available." I accomplished this many times using 13.0 and 13.5. Is this a bug with 14.1? How can I ready this. I need to show client that SPARX can support UAF.
Re: UAF ERROR:"Model Template Pattern failed to load.
« Reply #1 on: September 14, 2018, 01:40:10 pm »
I get that message when I click the "Create Pattern(s)" button and there are no patterns selected, for example when I have selected the group name instead of the contents.
iliab
« Reply #2 on: October 10, 2018, 04:54:22 am »
I'm in the (similar?) boat, I have just upgraded to v14, I'm attempting to use the Model Wizard and get TOGAF patterns.
The instructions in help file C:\Program Files (x86)\Sparx Systems\User Guide\model_domains\togaf_model_patterns.html suggest to navigate
Model Wizard window, select the 'Model Patterns' tab.
^-- this is as far as I get.
In the 'Technology' panel select 'Framework'
^-- I don't get the 'Framework' choice. The closest I can see is "Enterprise Architecture -> TOGAF". But then I get no pattern names and the same error as OP: "Model Template Pattern failed to load. Ensure the selected template file is available." error.
The items below are nowhere to be found for me:
and in the 'Name' panel select from the TOGAF Patterns:
•ADM
•Enterprise Continuum
•TOGAF Model (includes both ADM and Enterprise Continuum)
•TOGAF-Catalogs
•TOGAF-TRM
•FEAF-PRM
•FEAF-TRM
Does this have to do with me only having Sparx EA Professional Edition?
P.S. To clarify, I did download and install the TOGAF MDG add-in from http://www.sparxsystems.com/registered/reg_ea_down.html - no change in behaviour. TOGAF seems to just have a stub under Model Wizard ->Model Patterns -> (Enterprise Architecture) TOGAF for me.
« Last Edit: October 10, 2018, 05:18:46 am by iliab »
« Reply #3 on: October 10, 2018, 08:57:19 am »
According to https://www.sparxsystems.com/products/ea/compare-editions.html, togaf is included in the Unified or Ultimate editions.
It can also be separately purchased for the editions that don't include it.
https://www.sparxsystems.com/products/mdg/tech/togaf/purchase.html
ea0223
Re: UAF ERROR:"Model Template Pattern failed to load."
« Reply #4 on: April 26, 2023, 05:55:11 pm »
Is there a solution to this problem?  I am using EA 15.2.1558.  The model wizard displays the UAF template as an option (MDG shows UAF 1.1), but when I select the "Create Pattern", an error is generated "Model Template Pattern failed to load.  Ensure the selected template file is available".
