Author Topic: Named default value constraints  (Read 6001 times)
jaimecerda
« on: September 15, 2018, 06:59:47 am »
Hi I have a table in the database that was created with this script:
CREATE TABLE [dbo].[Catalog] (
    [RecID] INT            NOT NULL,
    [IsSpecial] BIT           CONSTRAINT [DF_Catalog_IsSpecial] DEFAULT ((0)) NOT NULL,
    [Name] VARCHAR (255) NOT NULL,
    CONSTRAINT [PK_RecID] PRIMARY KEY CLUSTERED ([RecID] ASC)
GO
Whe importing to Enterprise Architect the default value of column "IsSpecial" is setup as a column attribute.  In my case I want to have it declared as a constraint with name (as expressed in CONSTRAINT [DF_Catalog_IsSpecial] DEFAULT ((0)). )
Does anyone know how to make EA name a default value constraint?
Thanks.
« Last Edit: September 15, 2018, 07:01:47 am by jaimecerda »
Re: Named default value constraints
« Reply #1 on: September 15, 2018, 08:50:53 am »
There's probably no way. That part can not be configured. You might send a feature request, but I doubt you can hold your breath long enough.
« Reply #2 on: September 17, 2018, 09:18:17 am »
Looks similar to the primary keys and uniqueness constraints etc that are modeled using a separate stereotyped operation.
jaimecerda
« Reply #3 on: September 18, 2018, 12:31:30 am »
Unfortunatly the Default contraint type is not listed in the types dropdown, so that's why I can't name the default contraint  :(
The only values listed in the contraint type are:
PK
index
FK
unique
check
trigger
