Author Topic: EA Integration without Add In  (Read 4956 times)
Compadre
« on: September 19, 2018, 06:21:17 am »
Hi folks,
Is it to possible do develop some integration automation with EA without the need to develop an Add In? I need to develop a Windows Service that polls from a flatfile csv(comma separated) and updates some specific information into the model. I know that CSV import is available as well as MS Office Add In, but my customer requires this job to be automated and run as a windows services.
If anyone have any clues I will be thankful.
Thanks in advace.
Best regards,
José Compadre Junior
Re: EA Integration without Add In
« Reply #1 on: September 19, 2018, 06:48:20 am »
Running EA as service is almost impossible (though there a rumors that LieberLieber has some kind of solution). What you can do is to go directly to the database which should be reasonable with what I read from the short description. However, bypassing the API this way requires profound knowledge of what happens when doing so.
Glassboy
« Reply #2 on: September 19, 2018, 01:08:18 pm »
Because it's not a daemon, it's an obese client application.
OpenIT Solutions
« Reply #3 on: September 19, 2018, 09:24:44 pm »
Another option could be to get your client to install Pro Cloud Server and then use the web services interface provided. I've not looked at the interface yet - but I understand its limited, but could meet your requirement. See here:
http://www.sparxsystems.com/products/procloudserver/#oslc
Jon.
rwittmann
« Reply #4 on: September 19, 2018, 10:31:07 pm »
It will also work if you have a user logged in all the time. Automated task schedule can then access your model through the com module.
